I've been searching all day, but nothing is making since. A few days ago I noticed that my car has been burning more gas than normal. I get about 250 miles rather than 285 per fillup. So I checked it with my scanner and the code P0171 was there. I thought maybe that was because of Auto Shop that cleaned out my Intakes as they had to remove so parts to get down in there. So Anyway I cleared the Error and now the old P1131 comes back. I checked the MAF and it's clean. Some times when the car is at idle it likes to rev fine and then when the fans come on it idels to low at around 500rpms. It likes to do this alot.
Mercury Mystique 98 2.0L 4Cyl, has over a 100K miles.
Now for the last month or 2 I've been running into another problem. On very hot days the car has been shutting off while driving. The first time was right after my wife got back from driving around all day. I checked the oil and it was very low. So I filled it up and drove to work just fine. I got an oil change the next day and it's been fine for about 2000 miles. Now today after she was driving around it shut off a few times again. I checked the oil and it was just below the bottem nitch on the dip stick. I filled it up and drove to work just fine. There is only an oil light on once the car has stalled in the middle of the road. I just turn it off and back on and she goes again.
Do these cars shut off the car if the oil is low or there is a heat problem? If I'm losing oil I don't smell or see it, so I'm lost here? I replaced the gasket seal last year.
You would think the car would have a code for this. But the only code I keep seeing now is the P1131. I do have the VCT problem, but just have not got around to getting that fixed...lol
