I got a problem with the temperature gauge of my 99' Mystique . In the cold winter days, The gauge arm sometimes was stuck at the cold side or 1/3 from the cold. This happened for several times ,it generally back to work after the car is fully warmed up. I tought that is probably due to some frozen mechanism in the gauge.
But he problem was back since the day before yesterday, the gauge arm is always stuck 1/3 from cold side, it cannot go back to cold. But it does point to normal temperature after warmed up.
I checked the gauge sender , the connector looks fine , do I have a bad gauge ? I tried to test with the gauge sender, but found that I have to remove the hose to make some room....
any opinion ?
