Well, it only took about half of my sanity to sort this out, but I finally got to the root of my problem.
I replaced the plugs with new Autolite Double plats (they were worn to .060 gap), and replaced a marginal tube/hose running from the bank 2 valve cover to the accordian tube. The problem didn't go away, although the plugs helped considerably.
Yesterday I had about 130 miles of running to do in the region, and the morning started off with only a slight miss off idle when pulling away from stop lights. I was still not getting any OBDII codes. The problem got steadily worse all day, so I called a friend who is a tech at the local Ford dealership. He went on the Ford Oasis system to check for any new info and his advice was that 80 percent of the issues like the one I descibed to him are Mass Air Sensor failures, so I stopped and picked one up on the way home. I decided to check for codes one more time since the problem had gotten so bad. I finally got one, P0302! This is the same code I had when my coil pack failed a month ago!
I had a #2 plug wire from a set I replaced about 3 years ago still in the garage (sometimes it pays to be a pack rat). I put the old wire on and the problem went away! ARGHHHH!!! I took the new MAS back to the dealer this morning.
I just ordered an new set of Motorcraft wires, they will be in tomorrow. I will now have replaced the entire ignition system in one month's time.
I'll keep on repeating: I love my car, I love my car, I love...
