Originally posted by Spuddin:
Aight, I am new to the forums and just got a 99 mystique. No mods or anything. I am gonna mod it and want to start by adding a system. I am only 16 and on budget. I already have the head unit and 4 6x9's for the doors. I ****ed wit it and i cant find out how to take the **** off to get to the stock unit. How to I go about doing this? Anything will help and some pics would be great.
1st: sorry about the bad english... :p
You have to use those special tools mentioned above, or you can make your own with a wire coathanger.
Cut two 8-10 inch pieces, and bend them so that they can enter the two holes on each side of your original HU. Don't get them too far in - all the way in first, and then back just a little. The loops of the two "U"s should be pointing a little to each other, to the inside that is.
Now apply pressure on the loops from the inside, towards the exterior of the car on each side. Now you have to pull on the "tools" so that the HU slides out of the dash. It takes patience, and sometimes a third hand..
I did it with the coathanger trick, I wasn't able to find the "official" tools locally. The wires are used to release spring clips that lock the HU in its location. When you push towards the outside, you are releasing the clips. I had to pull on the HU itself while applying the pressure on the wires..
Don't be cheap, and go buy the wiring harness that will allow you to plug into the original plugs on your car! You'll be glad you did.
Kyo
