Posts: 1,217 |
I'm looking to replace my a/d/s 310rs.2 (10" dvc) with a SVC 10 of similar or better quality. It will be mounted in a very solid sealed box with an internal volume of .933 Cubic Feet. Power will come from a Nakamich PA1002 bridged to produce 360W into a 4Ohm load.
I am into SQ not muddy boom boom.
PLease feel free to offer any opinons or suggestions.
Posts: 4,585 |
Lambda PB $169 I think Dave has said the PB is the best sounding driver line and the power handling should be good for your amp.
Posts: 1,217 |
Posts: 1,083 |
That box is on the larger end volume wise. I don't think your amp is rated that high either! How much do you want to spend? BTW, why no more a/d/s? Good luck Try CRYSTAL CMP 10 maybe more than you need! or this cheap looking, great sounding CRYSTAL MobileSound 10" CSE This is a hard to find NAKAMICHI SPW100 . one of the best sq out there at a rediculous price. I can only suggest what I have owned/heard.
1998 SE ATX Dual exhaust Body conversion Nakamichi CD-40z HU Sound by Crystal Mobile Powered by a/d/s M860 AMP My Ride
Posts: 1,217 |
Price isn't really an issue. I want a SVC and a/d/s only offers DVC. The PA1002 is 100W x 2, when bridged it makes 200W x 1. You were right TonyD. Doh.
Hmmm, mabey I do need more power????????
Mark
Posts: 929 |
I am driving a PB10 with a Planet Audio Tube hybrid, bridged its 160 watts, and its plenty, especially in my Elements enclosure...which is .66 cu ft.
He's chaaarging!!!...(add scottish accent)...
Posts: 8,142 |
Originally posted by Trapps: Price isn't really an issue. I want a SVC and a/d/s only offers DVC. The PA1002 is 100W x 2, when bridged it makes 200W x 1. You were right TonyD. Doh.
Mark 100x2 at 8 ohm. It "should" double that into a 4 ohm load. I wouldn't be surprised if it was 360w x2. I would second the Lambda PB10. Best SQ woofer I have ever heard ( the PB series in general, not just the 10).
Posts: 1,083 |
where did you get the 100x2 @ 8 ohm's D? I must be missing something. I never heard the PB but I wouldn't doubt all the accolades. What about the A series from a/d/s? just a thought. You can get this IDQ10D2 V.2 in Dual 2 ohm. These are great in the SQ depo as are these PPI Pro 10 Let us know what you decide.
Posts: 1,217 |
OK, I'm now really confused. I want to start over. Here is a list of the gear I have:
NAK PA504 NAK PA1002 (2 pair) a/d/s 336im 1 a/d/s 310rs.2 (in a .933 cu.ft. sealed box)
I have considered all kinds of stuff, like ditching the 336's for a single pair of 346is' in the front doors driven from the 1002. and (4) 8's driven of the 504 in the rear deck. :p
OK gurus - make suggestions, all are welcome, including gear changes. SQ is the goal. I like tight fast punchy bass. speakers must be a/d/s and I'd like to keep the NAKs bu would exchange them for a/d/s amp(s).
Mark
Posts: 1,083 |
Trapps, why do you want rid of your sub? Could it be your box is a little big? Your equipment is all top notch. I would not go with 4 8's. I would go with 2 8's or 2 10's for sq purpose. I have 2 8's and they are solid! Your amps and speakers are fine too. I think your problem might be in your x-over setting. These are some of my choices. 8" subs Crystal mobile (must call directly, limited) PPI PRO8 10" subs Nakamichi SP-W104 Nakamichi SP-W100 Crystal CSE 10.4 Crystal CMP 10 PPI Pro10 These are only subs that I have heard and can suggest. As you know without the proper install they will all sound like a$$. Good luck. Personally I think your system has great potential but may just need some adjustment. Listen to a friends system and compare. BTW, what HU do you have? Cheers
