#1224435 03/24/05 03:39 AM
('96 SE v6 MTX w/122k mi)
Okay, so I cleaned the TB, found a vacuum line out of place (but i might have done it when i pulled the rubber off of the TB), reconnected it, checked all the connections underneath and the 02 sensors are both tight instead of rattling around like before, but still a check engine light. I think I can feel the engine loading up, so I am thinking its still running rich even though it thinks its running lean.
I originally pulled a 174/430 from the code reader from Murrays.
The IMRC got rebuilt about a year ago and I am assuming they replaced gaskets then, so they shouldn't be leaking. Any other places to look for a vacuum leak? Also, I used a "teflon safe choke cleaner" to clean the TB, is there anything else recommended to use that works better or gets further in?
96 Ford Contour SE MTX, SVT exhaust, KKM intake, SP Motorsports slotted rotors, KVR pads, SP5000s -Stereo sucks
#1224436 03/24/05 11:05 AM
Reset the computer, run it until the CEL comes on again, then have it scanned.
Steve
#1224437 03/24/05 12:03 PM
Trace the 2 main vacuum lines where they connect to the top of the UIM. 1 runs to the brake booster and the other runs to a main vacuum junction between the firewall and the motor. My guess is this is where you'll find trouble. Also check the neoprene tube which connects the PCV valve to a fitting directly below t-body bolt up on the bottom side of the UIM. Mine was cracked.
Redcoat Raceworks. Performance parts and custom fabricating for Contours, Mystiques and Cougars. Specializing in chassis and suspension parts. Custom end links, control arms, strut tower bars, engine torque braces, etc.
