#1224213 03/23/05 11:03 PM
E
eroto Offline OP
E
My moonroof got stuck in the tilted up position. THe switch doesn't work. I got in my car a couple of hours later and pressed the switch and it worked to get it back to normal closed position. Anybody ever had that problem and if so what is the deal?
#1224214 03/23/05 11:11 PM
Sounds like the switch is going out on you.
Totally sold out for a 90 GT vert.... 1/4 mile is almost the same as my modded svt w/n2o was...
#1224215 03/23/05 11:37 PM
DDV Offline
Click on Lance's sticky post at the top of this heading and then scroll down to "Quirks" and find "Moonroof stuck open/closed".
#1224216 03/24/05 01:02 AM
Online Content
Almost sounds like the gear unmelted itself (cooled down) just enough for you to close it.
#1224217 03/24/05 01:28 AM
That is the EXACT deal I had.. this was 1.5 years ago, so I now have more data..
I tried, knowing I would be screwed again, to open it and it won't open at all, now.. it grinds, and sounds awful when I press the switch, now (but, no movement..) The plastic gear inside melts from heat transfer from the sun on the roof, etc... Only fix is either replacing just that gear on your OWN (one guy is making metal fabbed ones, now...) OR replacing the entire unit at a cost of MORE than a clutch w/labor!
Get used to cracking windows, instead...
Ray
#1224218 03/24/05 05:12 PM
E
eroto Offline OP
E
So you never got this problem fixed Ray? I haven't tried to open it again.
#1224219 03/24/05 08:07 PM
gear
Here is the company tha makes the gear.
-tropictour
2000 Contour SVT Tropic Green SHO Shop CAI Bassani 1999 Contour SE BAT Kit
#1224220 03/24/05 10:57 PM
As stated about the pricing, no.. I haven't gotten this fixed.. LOL
I just learned to fully appriciate the complexities of air circulation and patterns with four windows... (how to create particular draftsz, and directions using combinations of each window..)
Ray
