finally I found a mid/tweeter that I think will fit on the two side rear view mirror panels
has anyone used these small tweeter/midbass before?
info
JBL GTO220 2.5 Inch 75 Watt Grand Touring Series Midwoofer/Tweeter
Features:
The world's first 2-1/2" midrange/tweeter allows you to optimize imaging by raising the soundstage in your vehicle
Only slightly larger than most separate tweeters, the GTO220 can be mounted virtually anywhere.
The GTO220 uses a pulp midrange cone and titanium tweeter to ensure ruler-flat response
JBL's incredible I-mount facilitates easy installation of the GTO220 in a flush-mount configuration
The 10.2t uses a full one-inch edge-driven dome tweeter like those found on high-end home speakers. This edge-driven dome significantly increases power handling and increases low-end response to 3.5kHz
Specifications
Speaker Impedance: 4ohms
Power Handling: 50 Watts RMS, 150 Watts Peak
Frequency Response (+-3dB): 3.5kHz - 21kHz
Sensitivity: 91dB
I-Mount™ (patent # 5,859,917) Tweeter Mounting System - This patented mounting system facilitates effortless flush, angled, or surface mounting of the component system tweeters.
Crossover Frequency: 3.5 kHz
Cut-out Diameter Tweeter: 1-3/4"
