#1221636 03/21/05 03:14 AM
9
9
Im new here so bare with me! lol! I have a 1999 contour se v6 with a 5 speed and I know the third gear syncro is going out and was just wondering what should I replace when doing this third gear syncro? Since i'm going to be in there anyways. What are the part numbers and where are the best place to get them. I read some other posts on this subject but i'm confused about what works with what year contour. What are the main differences between each year? What do I need to know before getting any parts? Any help will be greatly appreciated.
#1221637 03/27/05 11:03 PM
Welcome to CEG...
Get ahold of Bill Jenkins... hope he doesn't get mad, but here's some contact info from his sig:
Bill Jenkins
www.SignatureLM.com
parts@signaturelm.com
800-876-3280 x272
Goin' Round Traffic Circles @ 50Km/h!!! \m/ -- 1998 E0 SVT #2119 of 6535 \m/ -- 2003 Sentra SE-R Spec V
#1221638 03/28/05 01:00 AM
It would help to read the pinned note at the top about revised shift forks.
The person that knows this trans better than anyone alive is Terry Haines. Do a little searching and you should be able to find out how to contact him.
Also do a search on fluids for this trans. The right fluid may make the 3rd gear synchro problem tolerable without the expense of an overhaul. I would certainly recommend changing the fluid over to ATF+3 before doing a tear-down. If the improvement is significant, then you may want to try one of the synthetics that you can find info about from past posts. I have the Ford honey colored synthetic MTX fluid in mine at the moment with added Ford friction modifier and I have all but forgotten that there is a 3rd gear synchro problem.
#1221639 03/28/05 01:42 AM
#1221640 03/28/05 03:41 AM
I concur.
#1221641 03/28/05 04:36 AM
revised Shift forks, Torson or Quafe... You will be golden.
