First things first Good systems and $300 total on speaker and amp are oxymorons. Now I know not everyone can spend thousands, but one decent set of speakers and an amp to drive them could possibly be $300 but then you have to spend about $50 on accessories to wire them properly and 75-125 more to have it installed since you admit you don't know much about what you are doing. 2 ohm and 4 ohm are the impedence of the speakers. it's the load that the amp "sees" If you are running 2 4 ohm subs in paralell, the amp sees a 2 ohm load. You need to be sure that your amp is 2 ohm stable in order to do that particularly if you are bridging channells on a multi chanell amp. If you have a stock head unit I recommend pulling that first because it is a piece of ****. Go on ebay and buy from there. There are ****loads of wholesalers that sell new **** for 50% less than what you would pay at a best buy. Start with the head unit and speakers, then as money allows, get an amp for those speakers, then add another amp for subs. When selecting a head unit, you want flexibility to expand. Make sure it has at least 2 rca pre-outs for hooking up amps, 3 is preferable but not totally needed. Also, if you want a disc changer down the road, keep that in mind to make sure it has changer controls, and I don't mean those ****ty ones that work with an unused fm radio signal! Also, a helpful feature in a head unit is for it to have built in crossovers and equalizers. Once upon a time you had to pay big bucks to add that stuff in separate, now you can get those features in a quality Pioneer head unit for well under 300 (again look on ebay) Crossovers allow certain frequencies to pass, either high pass or low pass. You obviously don't want to be trying to push big bass out of your little 5x7's so the crossover allows you to cut off frequencies to those and then cut off the high frequencies to your subs separately. A lot of info I know, dont mean to swamp you but knowledge is power!!! Lastly, if you are one of those thieves who listens to MP3's make sure that your deck plays them and also that it will play cd-r's. Most decks made in the past 5 years play cd-rs without issue but MP3 capability is just making it's way to the masses. Oh yeah, did I mention XM satellite radio compatibility????
