josesvt Offline OP
is there a diference in the svt transmission and not svt transmission. for the contour?
98 svt contour, magnaflows, sho shop intake, sho shop high flow cat, no pre cats, custom cougars short shifter, 3 liter hybird engine woo hoo im happy, and just added a dmd underdrive pulley.
No.
only the 95-97 contour/mystiques.
E
E
If it comes with a clutch and flywheel then yes. If its just the trans itself any 98+ will be the same.
** Mike ** "You might beat me in a straight line, but I'll embarass you in the turns"
whats the diffrence in the 95 to 97?
rod shiter for 95-97, cables for 08-00.
rod transmits more vibration
cables stretch on hard shifts, some say they don't feel quite as good, and they can break easier. But I might be biased. Ask Russell....
-Philip Maynard '95 Contour [71 STS | Track Whore] '97 Miata [71 ES | Boulevard Pimp] 2006 autocross results
