I got my hands on an Alpine 7995 cd/mp3 deck (no internal amp, 3 4v preouts). I was replacing a JVC Kameleon so I figured it was a very easy procedure since I already had a a spliced harness. I re-spliced it for the Alpine and now the Alpine won't turn on. I think it isn't getting any power.
I am fairly sure that the wiring is correct from the Ford harness to the Alpine harness.
Got any ideas? I was gonna use a voltmeter tomorrow to check and make sure the wiring had the correct voltages.
Also, the original install had a small cube that had the two power wires, the ignition signal wire and the power antenna wire. The electrical digram shows a switch between two wires and the rest i cant really intrepret. I can upload a copy of the diagram if it helps. I took out the cube from the install thinking it was not important and maybe it isn't.
I will make sure to post pics when it is finished and working.
Have you put in your $0.02 to save contour.org?? Put in what you can spare to keep the site up. Check the General Forum.
David
* 2k Black SVT on 17" Konig/Yokohama
* MB Quart all around; Alpine 7995, DEI/Alpine amps; Dynomat
Soon to come:
19" HRE 445s under GC/Koni Setup, Custom passive-AWD kit, 2 small Sequential Turbos running low boost, Sequential 6-speed, Widebody Kit, custom black-red chameleon paint; on and on...
Use the voltimeter to test the ground and power wires. I recently had to rewire my whole system because of a faulty power wire.
That's not an optiistic response like I was hoping. It is possible that this is the case since my last deck no longer works.
David
Soon to come:
Dont qoue me for saying this but removing the "cube piece" is where i think you went wrong.
The cub piece is the power aand ground supply for the cd player if i am not mistakin. If all ese fails find another power ad ground and tap into that.
HTH
Chris Bertrand , !!16 years young!!
1995 Ford Contour Gl 2.5 V6 MTX
My DIMS (DO IT MYSELF) Achievements:
Performance Mods: None
Audio Mods:Jvc head unit, 6x9's in all doors , Sony XM-752EQX amp, 2 Sony Xplod LS-1235 12" Subs
Video Mods:Blaupunkt DVD-ME1, 2 5" monitors in sunvisors
Aesthetic Mods:Neons, Streetglow El Shift Knob
Commando LCD Pager Alarm
Many Mods To Come.......
I finally installed the deck successfully. It turns out that I had unknowingly blown Fuse 34 in addition to knowingly blowing Fuse 32. Before I noticed this, I re-installed the cube (still have no idea what it does) and replaced Fuse 34.
The 4V preouts and the overall quality of the deck surprised me. The radio has a sronger and clearer signal, the speakers are louder with half the gain as the previous deck.
David
Soon to come:
gotta love them alpines laugh :p
Give me more beer and CEG before i get depressed!
AIM/AOL: DBZ Jr
No thanks. I'll take my Clarion pro Audio piece over an Alpine. I've had three Alpines and nothing but problems. Maybe it is just my bad luck, but I will NEVER own an Alpine again. OK, not never but it'll be awile before my confidence is restored.
1998 Silver Frost SVT
Purchased 01/10/02
Mods so far:
-Fidanza aluminum flywheel
-Clutch upgrade
-Clarion ProAudio system, DSP, 13 Band EQ
Future mods:
-Intake upgrade
-Performance plug wires
-Autolite double platinums
-Konig 18 X 7.5 Toxxin's
-Koni's and Eibach coil overs
-Rockford amps, 3 12" Rockford subs, etc..
(Just needs to be installed)
yeah, a lot of problems with alpine decks over the past couple of years ranging from minor cosmetic flaws to performance issues. Those v-12 amps are the **** though!
Moderated by  dnewma04_dup1
