so, just for your info...
thanks for the point to the old thread.. I hadn't found it my search of the archives.
Well, I fixed it. It was a PITA. I went for the backup light switch... took me quite a while to get all the breather stuff off, and then found I couldn't get the switch out without also removing the starter (manual didn't say that). But... I then found out that it would be 3 days to get a new one anyway, so I just re-assembled it all without taking the starter out or actually getting the backup switch all the way off. Along the way, I noticed that the stealership had failed to connect a big vacuum hose connector that's under the throttle body. You can't see it with the intake in place. It's been that way since they charged me something like $900 to replace intake plenum gaskets and replace plugs and wires. I knew it hadn't been running great (seemed way too rich), but there was no CEL or anything... I thought maybe an O2 sensor was going bad, but not quite bad enough to trip the CEL.
Anyway, I put it all back together, now with vacuum line attached and it runs way better. Just for fun, I laid in the trunk, and yes the wires running to the lid lights (backup) were broken. Fixed them in < 10 minutes.
I guess I shouldn't complain about the hours spent playin' under the hood since I found and fixed the vacuum problem. But it does tick me off. How much extra fuel have I burnt in the last 18 months because of that???
Anyway, that's my story.
