#1218211 03/17/05 09:15 PM
Tom D Offline OP
How does the plastic trim around the radio deck in a +98 SVT come out? I took out the 4 screws holding it up, so the bottom portion is loose and the top doesn't want to move. I didn't want to break it, does anyone know if there are clips or something like that?
Working on life
#1218212 03/17/05 09:33 PM
It basically just pulls off. You kinda have to wiggle it back and forth. While pulling on the bottom away from the dash, push up.. THats how I got mine off and it didn't break. The top is held on with some panel type tabs (similar to door panels). Do it slowly, but firmly. Make sure to remove the two screws that hold the dimmer switch in when you get the radio bezel off, or if your too rough with it, you'll break the mount and or wire from the harness.
2006 Pontiac G6 3900SFI GTP Coupe CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint Former Owner- 2000 "Stryped" CSVT CEG Dragon Run- Oct 13-15
#1218213 03/17/05 09:35 PM
Tom D Offline OP
Thanks ill give it a try
Working on life
#1218214 03/18/05 01:41 AM
do not put alot of pressure on the DIN positions cuz i broke mine doing so. if possible remove radio (probably only if aftermarket unit) and use the left side of that for good grip. after that either do it slow and hard or hard and fast. if you do it fast you could lose the gator clips that hold it in, if slow you can put alot of pressure on the mounts. its a lose lose thing so take your time
05 Chevy Colorado z71 4x4 *for sale* 97 Honda Accord 4door track whore *12.9 N/A* (blown and wrecked) 97 Honda Accord 4 door 03 Eclipse GS
#1218215 03/18/05 01:40 PM
So what you're saying is that you don't have to remove a factory radio to get that trim panel off ?? It just slips around the radio ? I'm going on the hunt for a PRE-98 one this weekend .
~~~~~~~ Phil Black & Tan 2000 SVT Contour #2137 of 2150 35,000 miles & counting !
#1218216 03/21/05 12:57 PM
Well , I'll answer my own question :
YES , the stock radio should be removed before you remove that panel . The radio clips to it .
