Posts: 333 |
On my pre 98 zetec, Ive got a speed limiter that slows the car down at 110 mph, at the raceway, its too slow to be going.... has anyone removed or pushed one back? also, I was wondering if I had to mess with my compression to put a turbo or s/c on...
Posts: 21,653 |
What raceway are you going to that has a long enuff straight for a zetec to reach 112mph? and......... SEARCH
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 97 |
you can buy a chip,superchips or diablochip, to raise the rev limiter and get rid of the speed govenor. As with any application, raising the compression depends on how much power you are wanting to get, and how much time it's going to be spending on the street, or the track. Do a search, you'll be suprised to see how much info you can get in 10 min of searching
~ Fastest 95 Gl Atx Zetec in Long Beach ~
"Who would ever spend their money on a car that can't get 200hp N/A"
~ Slowest High Performance Car and Proud of it! ~
Posts: 7,012 |
Originally posted by Augi: has anyone removed or pushed one back?
how do you think hector got his car up to 640 MPH? i hear he was pulling on an f-16, they arent that fast from a roll. of course you can get rid of it.
Oo (xxx)oO
o xxxxxxxx o
Posts: 4,760 |
Originally posted by mikey boy: Originally posted by Augi: has anyone removed or pushed one back?
BUwhahahahah I love you maaan
Team Evo
Staz: You know why they call it Skunkworks?
Everyone: Why?
Staz: Because everything that comes out of it stinks!!!
Steeda-I hate you stazi
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by I-Dom-In-8: Originally posted by mikey boy: Originally posted by Augi: has anyone removed or pushed one back?
Me too....Mike that is too funny!
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 9,442 |
I can't wait to supercharge the Geo!!!!!
Posts: 862 |
Ok with my neon I removed my speed limiter without a chip. The speed sensor was wired in a T. Basically the speed sensor feeds both the speedometer and computer with a signal. So what I did was cut the wire feeding the computer, my speedometer still worked and my limiter was gone. After a few days the CEL turned on because the computer figured out that something was wrong. Anyway if the tours are setup the same way it should work on a tour as well.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
Posts: 259 |
I don't have a chip yet, but even I know that it will be a better worth while investment than cutting a wire on these cars. Especially if you plan on doing big mods to the engine.
I think there are a few companies that will reflash your ECU for you, if you don't want to buy a chip. That option may work out in your favor also.
Posts: 862 |
Well sure a chip will do more then cutting a wire. Shoot cutting the wire won't make you have more power, but it is a no cost way to bypass the speed limiter.
