To install a smaller belt, you would use the belt for a non-A/C car with the same engine as yours..
You didn't state WHICH engine you have, so you can just make that corrolation yourself. Any parts store should have the belt, and the routing diagram is in the engine bay, on the passenger side, near the serp belt, too.. look at the NON-AC routing and see if it looks like it will not work because the AC would still be in the way.... I think you will see, pretty plainly, what will work and what won't..
Ray
