#1215751 03/15/05 03:39 PM
Anyone have a fix for stiff shifter rod linkage?
I took the linkage off and worked all the plastic joints but its still tight.
CRASSELL 95 Contour V6 auto 96 Contour V6 5 spd 97 Contour 2.0 Auto
#1215752 03/15/05 03:47 PM
F
F
Auto or manual??? If it's your automatic that is stiff(which is common)it is the shifter assembly its self. I've found the best thing to do is remove the heatsheild under the car. Disconnect the cable. Drill a very small hole in the housing for the shifter assembly(just the size of the lubricant hose)and squirt the hell out of it through the hole with some WD-40 or PB blaster. Go in the car and work the lever back and forth a few times then repeat the squirting. When it's nice a free clean around the hole really well with some brake cleaner or alcohol and put a dab of silicone over the hole(not in it) to close it up.
Parting out 95-97 Contours/Mystiques. Contact me directly at ALFIGOLS@yahoo.com if you're looking for a particular part.
#1215753 03/15/05 04:50 PM
Sorry. 5 speed stick, rod linkage shift not cable shift. The problem is in the plastic insert u-joints.
#1215754 03/16/05 10:33 PM
Do you get this condition only in cold weather? If yes, there is a post on this website that explains how a different lube mixture will cure that ill. My Tour grew up in Buffalo, and it was a real "stick in the mud" in the Winter.
#1215755 03/16/05 11:28 PM
Especially first gear! They say it's like trying to shift through peanut butter...
#1215756 03/17/05 12:58 AM
W
W
You sure it isn't the gear oil in the trans itself??? When was the last time it was changed???
A1C Hodges, Christopher Active Duty USAF Sheppard AFB Texas;Westover ARB Chicopee, MA NECEG "Troll" formerly owned 2000 SVT Contour, with all kinds of goodies;)
#1215757 03/17/05 11:50 AM
Its the the plastic piviot joints in the shift linkage itself. I took the linkage off and worked it back and forth while adding spray silicone to the joint, but its still tight.
#1215758 03/17/05 04:46 PM
i had my mystique 5 speed that did the smae thing i took it off from the bottom under neath he car..i took off the heat sheild and dropped down the shifter and u will see the casing i think there is liek 5 bolts..i jsut opened that up and put some grease in there and worked it in mine was really dried out and it seems to perfectly fine now smooth as anything.. man i used to hate shifting to reverse when it was stiff and 5 ahah anyways my .02
