#1214937 03/14/05 08:32 PM
KenetiX Offline OP
hey everyone, ok before i get into this, here are the specs:
1996 Ford Contour GL 2.0L 4cyl Zetec w/Auto transmission @ 221,200kms
Sep 04 - New Front Pads, Rotors, Calipers
New Rear Shoes, Drums (remachined), wheel
cylinders, flex brake hose
Nov 04 - New Rear brake lines
Ok, now, here are the symptoms:
1) i rarely drive highway anymore, but the one time i did, after 5 mins, the ABS light came on, braking remained fine, i stopped the car and restarted, the light went out. Hasnt happened again since, that was like 1.5 - 2 mths ago.
2) On occassion, when braking (not neccessarily HARD braking either) the pedal will suddenly skip to the floor and i will hear a funny noise (ABS noise?) almost a rumbling sound, and the car will sort of skid to a stop. This happens even on dry pavement with no snow or ice and at slow stopping too.
Im just worried because i have spent now 800-900$ on brake repairs in 6 mths and i dont want something else to be wrong. Any suggestions on what this could be? or what i can check?
Thanks,
Ken
96 Contour GL 2.0L 4banger w/auto tranny @ 218,800kms
#1214938 03/14/05 09:17 PM
It does sound like false ABS activation. I would suspect a bad wheel sensor. This isn't usually something you want to guess about so have it tested.
