Posts: 145 |
I noticed this on ebay and I would like to know your opinions. If it is legit, would it be worth while for my car? Thanks, Stephen
96 Contour, GL, Zetec, ATX.
03/18/1996 Build Date.
Drop in K&N
NGK Laser Platinum Premium Spark plugs
Niehoff Premium Ignition wires
Wheel Well Air Intake Resonator removed.
*Just the beginning*
2000 Windstar SEL
K&N Air filter
Posts: 10 |
I would assume that its a scam. Notice that the dyno plot wasnt even for a contour, if it was real at all. All this probably does is make you run more rich. I'd save my money and get the real deal.
'95 Contour SE
Posts: 4,777 |
1st off - its ebay. second its for a 2001 contour. thirdly - mechanical engineers made it.
Posts: 379 |
It's a scam. Buy package of resistors from Radio Shack at a few cents each, and sell those resistors on eBay as ??Performance Chips? at $15 to $20 each, with instructions on how to install them across the IAT sensor, and unsupportable claims of performance gains to be had by doing so. If a five??cent resistor could really improve the car's performance in any way, without producing some other more significant adverse effect, then that's how the car would come from the factory.
Hyster E60XM-33
1996 Mercury Mystique GS, Zetec, ATX
To email me, remove the string HatesSpam from this address:BobHatesSpam@Blaylock.to
Posts: 5,882 |
Originally posted by Horse: 1st off - its ebay. second its for a 2001 contour. thirdly - mechanical engineers made it.
Posts: 1,746 |
I can't believe that after being a member of this site for over three years you still have to ask that.
Posts: 7,025 |
the resistor showed a 25 hp loss on a ford ranger. Theres dyno results to prove it. Run a search if you want to see it.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 2,033 |
This topic of "superchargers", "chips", or whatnot from e-bay has been gone over so many times, and they're all mostly scams! If you want the real thing, buy from a trusted, known company, not e-bay. Anyways, if your getting a chip, do it last, chips should be your last mod or else it will mess everything up.
Posts: 1,272 |
Yes, it is a scam. As someone wrote, all it is is a resistor that someone purchased at Radio Shack for .10$ and is now selling for 20$+ on Ebay. All is does is fool the ECU into thinking the intake charge is cooler than it really is....Oh, and you'll have to keep resetting the ECU as it will learn it's way around this "mod" rather quickly. Not worth the hassle, IMHO.
A1C Hodges, Christopher Active Duty USAF Sheppard AFB Texas;Westover ARB Chicopee, MA
NECEG "Troll"
formerly owned 2000 SVT Contour, with all kinds of goodies;)
Posts: 4,693 |
100% Pure Unadulterated SNAKE OIL!
Jim Johnson
98 SVT
03 Escape Limited
