josesvt Offline OP
ok guys here it is.... for the past 3 weeks ive been having a hrd time shifting to 3rd gears. it would grind. since sunday it was getting even harder to 3rd gear. but today on my way home from work on the fwy. my tranny just gave out. none of my gears ingage. i tried changing the gears manually with my hand on the tranny and same problem. what could be the problem. if you guys might know or give me a clue what i can do. thanks for the help.
98 svt contour, magnaflows, sho shop intake, sho shop high flow cat, no pre cats, custom cougars short shifter, 3 liter hybird engine woo hoo im happy, and just added a dmd underdrive pulley.
well the grind in 3rd is the synchro's. as for why the tranny gave out cant help you there unless you give more info as to what happened, what is happening and or not happening
98.5 Black SE ATX S&B filter, SVT MAF, optimized SVT TB, mesh grille, removed orange reflectors, painted rear reflector, gutted pre-cats, optimized SVT LIM, 19lb injectors, resonator removed cant afford an svt but lookin for 1 in nc
Did you have a bad clutch or a possible leak of fluid because with what your saying there is more to the problem then what you stated initially.
