Posts: 273 |
I just contacted the CC in my area and asked how much it would cost for them to replace my busted Profile Baja 200 two channel amp with a Profile California 600MSX amp which I figure is simply an unplug and swap job, you know 1) unplug the wires 2) remove the old amp, 3) put in the new amp, 4) plug in the wire 5) adjust and that they would charge me $60 plus tax. Should I be outraged!!!!!!!!!!
So tell me moderators is there more to that which I am missing.
Posts: 8,142 |
60.00 seems about normal for an amp installation. Did you specify that it was simply a swap and not a full install?
Posts: 1,032 |
Do it yourself. Screwdriver and 5mins tops. There ya go!
1999 SVT #900/2760 Born on 1-20-99 Silver Frost/Midnight Blue A few aesthetic and audio mods
Posts: 85 |
They probably assumed a new wiring job with thicker gauge wires for the move from 200-600 watts max. This probably really isn't necessary, but is always a good idea so you don't short/burn up your amp.
98.5 SVT E1, Silver Frost 5083 / 6535 born 3/18/98 Removed Resonator, K&N Filter Complete audio system mods Painted Interior & Calipers, Xenon bulbs ON THE WAY: B&M, Aussie Bar, DMD ------------------------------------- 1964 Olds Cutlass F-85 Convertible ------------------------------------- 98 SE Black, Deceased
Posts: 273 |
Yes Dave I mentioned it to them that it was just a swap. I have the heavier gauge monster cable reference wires or amp cables in my car already for accessories is how CC makes their money and so the gave me an expensive amp cable kit.
Posts: 273 |
Well SVT Colin I would do it myself but currently the location for that amp is under the rear deck and I must say the 600MSX amp is much heavier than the BAJA 200 and I would have to drill holes thru the rear deck metal and wood carpet while looking up and so I figured I might as well change the location of the amp in the mean time to the back of one of the folding down seats. I wonder if that amp will fit there? considering its length along with the other 4 channel amp that I currently have located there?
Posts: 30 |
Just for your info you dont need any higher gauge wiring then what you currently have. also I wouldnt pay for them to install it, it is way to simple to do by yourself. Just pull out the inline fuse and you are safe. Car audio places will just rape you on installation of anything, and car audio has to be one of the easiest things I have ever experienced doing. Dont bother with them when you can do it yourself.
99 Mercury Mystique Red (toredor) ATX 2.5 V6. Stock right now excluding sound system.
Sound System: Alpine CDA-7864 Infinity Kappa Components 5.25 Infinity Kappa 5x7's (rear) 2 12" JBL Power Series Subs Rockford Fosgate 160a2 (interior) Crunch 4004C (Sub Amp) Phoenix Gold Power Wire, Fuse Holder, Distribution Blocks, Speaker Wire, and RCA's.
Future Mods: KKM intake Indiglo HVACS and gauges (hopefully SVT) SVT exhaust Stock SVT wheels Body Kit? email if selling any of these items.
Posts: 452 |
Originally posted by Jon Gordon: Just for your info you dont need any higher gauge wiring then what you currently have. also I wouldnt pay for them to install it, it is way to simple to do by yourself. Just pull out the inline fuse and you are safe. Car audio places will just rape you on installation of anything, and car audio has to be one of the easiest things I have ever experienced doing. Dont bother with them when you can do it yourself. I'll never forget the day I realized how easy car audio installation was...it was a sad day, thinking about all the money I wasted because I didn't want to take a day to figure it out.
Silver E1 I'm afraid Speed Demon has given me the mod bug. AIM: Davo7Wins
Posts: 273 |
Jon Gordon sayd "Just pull out the inline fuse "
what is an inline fuse for the amp the fuse on the battery what Gordon?
Posts: 91 |
The fuse in on your amps power wire. Should be located up close to the battery. Just out of curiousity, what guage of power wire do you have ran?
Joel Falkenberg
