#1207296 03/07/05 04:57 AM
JJsvt Offline OP
I was wondering if anyone could help me... I have a 98 svt contour. It is stock and has ~93000 miles. Recently, the car has been losing power on the high end (after 4000 rpm). It doesn't sputter....it just doesn't have the power that it should (ie it doesn't pull to the redline with tenacity). I brought the car to the dealership and they did a tune up, replaced fuel filters, and recent replace the ICV (the car started to idle poorly). These things fixed the idle trouble and the power loss for a while, but the power loss has returned. I should also mention that this doesn't always happen. Sometimes the car runs fine and has plenty of power. The dealership doesn't seem to know what to do since no codes show up and they just did the tune up. Anyone have any ideas???
Also, the car revs when the AC/defroster is on. Any ideas why this happens? I believe that it should lose power when the pulley is engaged.....not surge with power.
Thanks
W
W
I would like to stress that I am by no mean an SVT expert- but it could be a fried (or otherwise inoperable) IMRC unit. These have been a problem for the V6 contour from what I understand, and a symptom of their failure is a loss of power at high RPM.
Regards,
Matt
I
I
I also suggest looking at the IRMC unit. it has a multi-strand cable in it that goes bad. as strands of the cable break, they get caught in the housing. you can check for this by removing the imrc cover and looking under the circuit board. be careful not to damage the circuit board connections.
contours, deloreans & fiats, oh my!
I had this problem in 2002 right after the stealship did a recall repair. My symtoms were exactly as you describe. They kinked the IMRC cable. It was replaced for no charge (after I made a very public stink in their service department). They tried to claim that it was just worn out until I showed them the very obvious kink and incorrect routing of the cable.
'96 SE 2.5 V6 ATX, Willow Frost Metallic 10-hole '84 Mustang 15x7 wheels w/ Dunlop 225/50-15's CSVT air intake components with K&N cone filter Optimized TB Gutted Pre-cats w/MIL eliminators
Great dealership that can't even diagnose an IMRC issue.
How common are secondaries anyway? I hadn't heard of them before getting my Contour.
98 Contour V6 MTX, T-Red, 150k mi. Pic SVT Dual Exhaust, KKM Intake, Donnely Mirror, Dension DMP3 Player w/80GB of MP3s, Wheelskin 95 F-150 91 Mustang GT 06 Honda Shadow Aero
Not sure but I have them on my SHO and they started the manf. of the Yamaha in 89.
Sounds like your fuel pump is going out. Does occur more frequently when you have a quarter tank of gas or less? Does it buck?
"Eagles may soar high, but weasels don't get sucked into jet engines."
and also after you get that imrc cable fixed if thats the problem, think about getting either a sct chip or flasher, that will give you alot more power through all power levels....gimme a pm and i will hook you up with one
