#92457 07/07/02 02:45 AM
I need to know how to hook my power antena To my Custom Pioneer ...I know it is supposed to Hook up to the REMOTE wire but i am going to use that for my AMP and also the Wire from my stock radio for my power antena has a Weird Looking hookup . Please help Chris frown [email]PimpinAintEZ85 @aol.com[/email]
Try running your remote to your amp and your antenna, usually you can get away with it.
Joel Falkenberg
there should be a remote antenna wire from the pioneer deck. Should be blue, or blue with white stripe? not too sure, but that goes to the power antenna. Connect the power with a distribution block, and ground it. should be set. Hope this helps!
Ren
Give me more beer and CEG before i get depressed!
AIM/AOL: DBZ Jr
DBZjunior what are you talking about. Pioneer head units only have one wire for both amplifier turn on and power antenna. It is a blue with a white stripe. If you are good with relays you can use a relay for the separation but you don't have to. I have a Pioneer DEH-P9300, I use that same wire to work my power antenna as well as 4 amplifiers. So I know that it will work.
Moderated by  dnewma04_dup1
