#1206549 03/06/05 02:27 AM
Had a ton of work to do on the car. Leaking LH halfshaft seal, leaking LH Koni. So I wanted to fix all that and put in the camber adjusters too. After I pulled the halfshaft and replaced the seal, and had the struts out anyway (got a new Koni shipped, sent the defective one back), decided what the hell, might as well do the headers too.
Headers were really no problem, just pulled LH knucle, half shaft and intermediate shaft, alternator. I actually found installing the fronts a challange due to very tight clearance with the cooling fans. Got everything back together and dialed in the camber with the SmartCamber tool. I had inner tire wear issues with the Koni/Eibach setup, even though alignment was supposedly within spec.
Great doing this with alot of tools and well equipped heated garage with a lift
With the front all done, now I have to install the ATI subframe and Aussie bar (typical busted stock bracket issue) , spherical endlinks, upgraded bushings, slap on the 17's with my new Goodyear Eagle F1 GS-D3's and dial it in.
Thinking about the Canyon Run this year, sounds like fun.
98 SVT T-Red. 17" Borbets w/GY Eagle F1 GS-D3's, Koni/Eibach setup, urethane suspension bushings. Aussie Bar. Battery in trunk, open K&N Filter. B&M Shifter. Gauge pod w/ volts, oil pressure, oil temp. Sparco drivers seat, Schroth harness belt
#1206550 03/06/05 09:11 AM
HOLY CRAP BAT MAN !!!
That is a list of work. I bet that thing is going to just sing. Were did you get the Aussi bar ? That is the last thing I need to finsh the CSVT. There wont be anything left to mod ! lol I also am very jellus, your garage sounds awesome, you hit the lotto ??? Can we have an install day at your place when all us CO CEG'ers get our new Aussi bars ?
If you can, make the meeting next Tuesday, I would love to see all the work you have done. Hope you can make it. -B.
1998 SVT With a few mod's RACECAR IS RACECAR BACKWORDS ! #970 of 2395 Black/blue *****FOR SALE*****
#1206551 03/06/05 12:57 PM
Bought the Aussie bar when they first came out, installed, and then of course the brackets tore. So been running without it for awhile...will be great to get the backend up to snuff again.
I'm a general contractor and the garage is at a used car lot that I remodeled for the owner. Used to be a Mobile gas station. I have a yard back of building where I store my trailers, and in exchange I maintain the building for him.
#1206552 03/06/05 03:26 PM
Hey Llon (sp?) good to see you! That is one heck of a mod list! I thought you had moved to S. Colorado some where.
Derek Scion xB 5-spd Previous: 2000 Silver Frost SVT Please share the road with cyclists.
#1206553 03/06/05 09:56 PM
Got the tools, but Im jealous of the garage and lift
-Ken V. 1998.5 SE Praire Tan Zetec ATX psycho_bass@hotmail.com Roush springs Roush rear sway bar BAT struts 17" Millie Miglia HT3 and a ton of subtle asthetic mods
#1206554 03/06/05 10:39 PM
Hi Derk. Yes I did move to the San Juans for about a year and a half, but back in Denver now. I see you moved to UT.
Yep, having a lift to do this type of work is golden. Best thing since the Olson twins turned 18......
#1206555 03/06/05 11:00 PM
Ah the San Juans... Denver aint bad either.
I started grad school up in Salt Lake back in August. It's been a great change! Did you see I sold my 'tour... (puts on flame shield to protect against SW CEGer's comments )
#1206556 03/07/05 09:28 AM
HE BOUGHT A BOX !!!! oh yeah, it has wheels too ! lol j/k -B.
#1206557 03/07/05 12:11 PM
Derk, why did you lose the Tour? Thought you had some nice mods on it.
#1206558 03/08/05 01:39 AM
I had about 5 things break when I moved up here. I decided to cut my losses, sell the car, and buy a Japanese car.
Moderated by  Keyser Soze
