Posts: 72 |
okay folks...i have access to a '93 3L taurus engine.....and i'm thinking about a swap...but will a tranny from a 2.5L contour or mystique bolt up to it? and are all the mounts the same...ect ect ect....i've searched, and found mixed emotions.......lemme know what you think
[IMG]http://img35.photobucket.com/albums/v106/psychojetpilot/signature.jpg[/IMG]
Posts: 6,760 |
If its a 93 SHO engine its a direct swap!
Ryan
Trollin!
Posts: 110 |
Posts: 72 |
i realize that now...i found a post on another site somewhere saying 99+ you can swap in.....so i guess its back to the drawing board for me...lol...thanks again for the help, and sorry for the inconvenience of this post!
Posts: 5,810 |
For sure as early as '98, maybe '97 too.
Must be a duratec though.
See My Mods
Posts: 9,602 |
They changed the bell housing during the early part of the 98 model year.
To make it easier...
99+ for a hybrid. 01+ for a full swap.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 5,810 |
Yes, but the only difference on the bell housing was that the upper right bolt was offset by about 1/2". The space for the upper right bolt to be tapped into the block was already designed into it so you could either tap a second hole in the block for the upper right bell housing bolt, or you could drill a hold in the transmission next to the other one. The latter is what I did and I did a few cool things to make the mounting ear on the bellhousing stronger. Now my transmission can fit either 98 or 99+ blocks with either bolt hole. This really wasn't a difficult problem to overcome and although tapping the engine to provide the "right" bolt hole would be the stronger of the two solutions, I never broke anything on my engine with tapping the trans mounting ear and I was running it that way with the turbo.
See My Mods
