I have a 96 Zetec with 76,000. It has been losing coolant recently although I cant locate where. Sometimes with the heater on you can smell antifreeze lighty, and it goes away and comes back when it wants to. Also when you get out of the car you can smeel antifreeze smell.
I did a pressure test today built pressure to 16psi, and it dropped steadly, indicates a tiny leak.
I have checked all hoses, and clamps no leaks clamps are tight, the radiator is less than two years old.
The hose going from the coolant recovery tank to the thermostat housing is hard though for some, like pretty hard not soft dont know why that would be.
I'm leaning very much to the heater core, only reason I havent done it yet is because it hasnt been wet on the passanger side flood board.
Any ideas thanks
