2
2kSVT Offline OP
Hey gurus..got a problem. The past cuople of days I have had a problem with the SVT. Today I was driving on the highway about 70 mph and out of the blue the car "chugs"..like it stalled and then it was fine.The wierd thing is when it did this the abs,brake, etc dash lights came on and the power loss was long enough that my radio turned off! It was like I turned off the key and then turned it on again.(as in the dash lights coming on).
The car has 70,000 miles on it,new fuel filter a month ago,new positive battery cable a couple weeks ago.
Talk amongst yourselves!
Rod
-2000 SVT-Silver Frost/Midnight Blue #1,382 of 2,150 Born on 01-07-2000 It's got stuff -2003 Lincoln Navigator-Ultimate Silver/Midnight Blue -1997 Kawasaki Vulcan 1500-custom paint,CHROME
how many alternators has you car gone thru?
2
2kSVT Offline OP
It's still on the stock one. I have a different head unit, but no other stereo stuff.
Rod
Sounds like an intermittent supply connection.
First thing to do is to service both battery terminals. Remove and clean them.
Might be an intermittent ignition switch, also.
Steve
Same problem
It was the BATTERY TERMINAL- [small one] Corrosion !
1999 GREEN Contour SE SPORT Duratec V6, ATX, SUNROOF, 93,000 Miles, P0420 ON&OFF -replaced DS O2 --did not FIX *New TORQUE CONVERTER @ 53,000-Intermittent P1744 *New DASH at 53,000 and New DASH lifted-now using MOLLEY bolts to pull down
2
2kSVT Offline OP
Like I said in the first post..I just replaced the positive cable a couple weeks ago. The positive cable corroded into 2 pieces! I got a new one from Ford,for $118.00. The sell the thing as an entire assembly...positve/negative cables plus the in line fuse junction.I'm puzzled.
Rod
