#1203954 03/03/05 03:53 AM
Temujin Offline OP
It seems like my car is leaking oil from the oil cap. I figured it was due to an old, worn cap so I bought a new one. Now, it STILL leaks... every time I clean the area around the oil cap, it gets a film of oil around it after a short trip. Any ideas on how to correct this? Is the oil pressure too high? I rather doubt it since oil is actually being lost.
#1203955 03/03/05 04:33 AM
CEG road warrior
CEG road warrior
Maybe it is your valve cover is leaking.
#1203956 03/03/05 04:38 AM
Question. Is the new cap OEM and does it click when you tighten it (like a gap cap clicks when it's maxed out)?
1992 Ford Escort LX-E -Tracer LTS spoiler -GT Grille
#1203957 03/03/05 02:27 PM
or maybe, just maybe (but i doubt), did you over fill it by anychance, cause the oil would force itself out
-Contour's dead, but is being revived...
Originally posted by CSVT1214:
Originally posted by ford zetec2:
after than, what do i do with the 98 short shifter? do I place it in there like it is?
Stick it in your butt and rotate.
#1203958 03/06/05 07:17 AM
W
W
I overfilled my oil system once and my exhaust blew smoke out for a while. I had to drive hard to burn off that oil during my road trip. It cleared up around somewhere in Arizona, after I left from San Diego.
I think it might be the gasket also, but check your cap and see if there is an O-ring around it. I'm not sure, but I think there should be one there to help seal and keep the cap from leaking.
