Posts: 155 |
I chipped a small piece of my Mirko and simply need to know what material I should use to patch it? The damage is around the outer lip part, pretty small, but visible. I'm no fiberglass expert here!  Greg
2000 Silver Turbo CSVT (((FOR SALE, PM me! $12K)))
1999 Vibrant White Cougar
Posts: 6,106 |
Bondo.. It's been a good friend to me since my Mirko install. Mine sits about 2" off the ground with the Eibach/Koni suspension.
Mark
2000 Black CSVT
Posts: 155 |
Mine sits about that low also, just had it painted a week ago, and some jerk ran me off the road!  Is the Bondo "Body Filler" the appropriate thing to use? Greg
Posts: 7,025 |
yeah, thats what you want to use. My best advice is to apply it to the area needed and shape it as best as possible. The warmer the outside temperature is, the faster this stuff drys, so if your doing this in a cold garage it may take awhile. Anyways, whenever ive used this stuff, i usally dont wait for it to cure completely. Wait for it to get pretty hard, but somewhat soft enough to where its easy to sand to the desired shape. Sometimes it may take 2-3 applications to get the desired shape you want.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 155 |
I was thinking of doing the same thing. Should be relatively easy on such a small area. I'll let you know how it turns out.
Greg
Posts: 1,423 |
Originally posted by TheFordGuy: Mine sits about that low also, just had it painted a week ago, and some jerk ran me off the road!  Is the Bondo "Body Filler" the appropriate thing to use?
Greg
I'd use the Fiberglass Reinforced Bondo over the plain filler. It holds better and has a better chance of not cracking and breaking loose. http://www.bondo-online.com/catalog_item.asp?itemNbr=208
Scott
2000 Contour SVT #1464
Mustang Dyno: 171.6hp/145.3lb
Dynojet Dyno: 171.1hp/148.9lb
1989 20th Anniversary Turbo T/A "Indy 500 Pace Car"
#1376 of 1550 All Original, 46k with a few mods
2002 F150 SuperCrew
Posts: 4,141 |
i recomend duraglass-easy to work with, tough as nails, and dry to sand in about 20 minutes. this is what i'm using right now to repair mine.
Josh
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 5,600 |
Originally posted by pole120: i recomend duraglass-easy to work with, tough as nails, and dry to sand in about 20 minutes. this is what i'm using right now to repair mine.
Josh
where can you find that?
Black 1998.5 CSVT
Posts: 4,141 |
i got mine at the local car paint and body supply store. i doubt autozone or the like cary it, but it's worth a shot.
it's not cheap- just an FYI
Totaled 02/12/06
Posts: 5,600 |
Originally posted by pole120: it's not cheap- just an FYI
hmm, well thanks for the info but im probably going to pass. the fiberglass bondo is about 11 bucks at the local home depot.
Black 1998.5 CSVT
