#92210 07/01/02 06:51 PM
I am designing a sub box using my modeling software at work, this way I can easily determine the size of the box with proper volume allowances. I would like to know if anyone knows the angle that the rear seats form with rear deck of the trunk. I would like the face of the box to match the rear seat to trunk opening when the seats are down.
1998 Silver Frost SVT
Purchased 01/10/02
Mods so far:
-Fidanza aluminum flywheel
-Clutch upgrade
-Clarion ProAudio system, DSP, 13 Band EQ
Future mods:
-Intake upgrade
-Performance plug wires
-Autolite double platinums
-Konig 18 X 7.5 Toxxin's
-Koni's and Eibach coil overs
-Rockford amps, 3 12" Rockford subs, etc..
(Just needs to be installed)
#92211 07/01/02 08:08 PM
I really don't know the exact angle of the car seat. But what I usually do is just take some cardboard, and make template out of it. Angle it as close as possible, and then work with that. It's actually a BTCH to actually get it exact, but it's worth it.
Give me more beer and CEG before i get depressed!
AIM/AOL: DBZ Jr
#92212 07/01/02 08:39 PM
The only reason I ask is because I am modeling it on SolidWorks at work, so I need an accurate number. It doesn't have to be exact, just close. The reason I am doing it this way is because I am squeezing 3 12" subs(2 facing into the cab and one facing into the trunk with amps on each side) into the rear deck. So the chambers in the box are obscure shapes and hard to calculate accurate volumes.
Purchased 01/10/02
Mods so far:
-Clutch upgrade
Future mods:
-Intake upgrade
Moderated by  dnewma04_dup1
