JOHNE Offline OP
pictures
Well here are some of the pictures I took. You can check out the home made cross-overs. They work perfectly. The grill has been drilled out, but you can't really see all thats been drilled out in the pictures due to the curvature in the grill itself. Putting the McMasters on took a while. You can see that it looks completly stock when back together again. I haven't heard the speakers with the pannels back on yet because my amp had to be sent back, but with them off it was awesome.
Time to get to work on the trunk.
Cheers
John
W
W
Did you put back that foam cover in the door?
Just curious
jack
He's chaaarging!!!...(add scottish accent)...
JOHNE Offline OP
Yeah, I just cut a big circle out from where the speakers are and put it in there. I didn't want that huge opening towards the rear of the door uncovered.
JE
E
E
Lookin' awesome, John - great work! Now, just get that amp back so I can give it a listen already... :p
'98.5 T-red SVT
Moderated by  dnewma04_dup1
