as long as the Volts don't drop below 12, everything is okay and you need a new alternator, and if you are going to run two batteries MAKE SURE to run them in parallel(+to+ and -to-), if you run them in succession+to- and -To+, you will end up with 24 volts, and the need to buy a new stereo
