Posts: 408 |
Is that a subzone box? That's what my sub is housed in. I like it, great quality for a really good price.
vinny "2000 T-RED SVT" Mods: kkm sho shop off road y-pipe Audio: Alpine CDM 7874 Audio Control 4.1 EQ/Line driver Mb quart rsb 215 comp. Mb quart rsc 216 comp. blueprint 1001 sub 2 Phoenix Gold qx2180 amps
Posts: 131 |
Mine is very similar to louisw's but the mack in made of aluminum and is hinged so it can swing down for show. I reall don't know why I did that because I've never taken it to a show. Maybe some dav I'll get some pic's posted.
'98 E0 T-RED CONTOUR SVT #558/6535 Got Tunes: Sony CDXC-90, CDXT-65, XDP210EQ MCINTOSH MC4000M BOSTON PRO 6.5 COMPONENTS BOSTON PRO 12.5 LF POLK DB4500 STINGER 1FARAD CAP RED NEON INSIDE AND UNDER THROTLE HANG FIX RESONATOR REMOVED
Posts: 929 |
Sliding,,that is what I had in mind...like sliding shelves...
He's chaaarging!!!...(add scottish accent)...
Posts: 48 |
Hey Louis, that looks like my amp, and my sub's box looks similiar too, except it's a Qlogic..
Thanks, so far, for everybody's ideas and pics..
Frank
Posts: 730 |
Mine's also under the rear deck, like so:
Kendall '97 GL Zetec ATX " Nippy "
Posts: 3,950 |
Mine is mounted to the back of my sub box.
Posts: 860 |
My amps are hidden rather well... [img]http://www.fototime.com/ftweb/bin/ft.dll/standard?pictid={52FB4BD0-EF02-4593-927F-AD7871285055}[/img]
I have two amps and two crossovers mounted beneath the rear package tray, on that carpeted board you see at the top of my trunk. It is hinged towards the front for access...
I then have my sub amp and my equilizer mounted behind my custom trim panel on the left side, on rails, to give it a free-floating effect, as illustrated below: [img]http://www.fototime.com/ftweb/bin/ft.dll/standard?pictid={7D17E485-345F-499F-8E6A-409765EEFD7B}[/img]
Posts: 929 |
Can you explain in detail how you did that rail system,,,,pleeaase??
Posts: 3,774 |
kai -- i like that install. very original.
i had my amp mounted on a carpeted board behind the rear seats.
the new setup will see my amp(s) face down, under the rear shelf.
1998 E0 SVT #3128, T-Red
2001 Infiniti G20t 1974.5 MG B GT
Posts: 1,032 |
Originally posted by bacoSVT:
the new setup will see my amp(s) face down, under the rear shelf. mounting amps upside down = teh bad No heat dissipation through the heat sinks, hot amp, distortion, possible damage.
1999 SVT #900/2760 Born on 1-20-99 Silver Frost/Midnight Blue A few aesthetic and audio mods
