#91962 06/25/02 02:31 AM
W
whiteSE Offline OP
W
Do the 4 ch versions have a separate X-over for each pair of channels?
Channel 1-2 for the tweets and channels 3-4 for the midbass, with their own xover?
I think i may buy one or a 2 chx100
He's chaaarging!!!...(add scottish accent)...
#91963 06/25/02 03:01 AM
I think it has 2 seperate cross overs for the 4 channels (front X-over and rear X-over). I'm not too sure. I'd have to check it out on the webpage if anything.
Give me more beer and CEG before i get depressed!
AIM/AOL: DBZ Jr
#91964 06/25/02 03:08 AM
W
whiteSE Offline OP
W
The web site only says that it has a variable low and high pass....but they dont say if its per pair of channels..
I am looking at an older gen...the MC420
#91965 06/25/02 03:12 AM
V
V
Most likely it is two seperate, but don't quote me on that one.
vinny "2000 T-RED SVT"
Mods:
kkm
sho shop off road y-pipe
Audio:
Alpine CDM 7874
Audio Control 4.1 EQ/Line driver
Mb quart rsb 215 comp.
Mb quart rsc 216 comp.
blueprint 1001 sub
2 Phoenix Gold qx2180 amps
#91966 06/25/02 04:40 AM
im confused, are you wondering if theres a possibility of one for EACH channel, or one for the whole amp, etc? i cant say i know of any 4 channel amps with 1 crossover, since isnt a 4 channel amp essentially 2 smaller 2 channel amps connected together? so it wouldnt make much sense. id guess 2
#91967 06/26/02 01:43 PM
The amp does have two seprate x-overs if it's similar to the MC420M I used to have. But will only do a low pass and a high pass as in running a sub on channels 3 and 4 and components or coaxes on channels 1 and 2. This couldn't be used as an active x-over for a mid and tweet. I hope that was what you were looking for. smile
'98 E0 T-RED CONTOUR SVT
#558/6535
Got Tunes:
Sony CDXC-90, CDXT-65, XDP210EQ
MCINTOSH MC4000M
BOSTON PRO 6.5 COMPONENTS
BOSTON PRO 12.5 LF
POLK DB4500
STINGER 1FARAD CAP
RED NEON INSIDE AND UNDER
THROTLE HANG FIX
RESONATOR REMOVED
Moderated by  dnewma04_dup1
