The Mechanic replaced my coil and the plugs. He said that the coil had a burnt spot on the underside. He drove it and the light was off, but when he got back the CEL came back on and he said it was the Cam Sensor again. The first Mechanic that I took it to replaced the Cam Sensor. So after this one replaced the coil and the Code came back in, he looked at the Timing Belt. The belt was loose and had skipped time. He said that he could tighten it up and would probably last for a little while, but I would sooner or later need to have it replaced. So I told him while he had it tore apart to go ahead and replace it. Good thing, he said it had two spots that were messed up on it. So after he changed the belt, I was hoping it would be the end of the problems. The CEL is still on and the code is still there. So now he is going to check on the wiring today to see if he can find something there. I am hoping I will be bringing my contour home today fixed!!
