Posts: 220 |
will carpeting the inside of a box- kill any/much of your sound- jlAudio 10w0's (2) in ban-pass ported thru back deck-??
silver frost 98' svt--tint, stereo system, kkm intake, glasspack, optima, carbon fiber, superchip, side markers, adj. koni's, eibach's, coilovers, axis 7evens 19x8, nitto 225-35-19
Posts: 3,950 |
Why would you want to carpet inside the box? You can do it (bandpass boxes usually have carpeting in the front of the box). I don't think it would affect sound much if any.
Posts: 111 |
Do you want to dampen vibrations? If so, try acoustical foam or carpet padding.
rimmie
Posts: 8,142 |
It will not effect the volume of the sub.
Posts: 220 |
sorry for not explaining better- the rear of the box is 3/4" plexi- and inside the box now it is painted-with a carpeted cover panel with large window openings- ( just outside the plexi)- but I am tired of it- and thought it would be nice to add carpet- inside to match the rest of the trunk- - between the plexi back and the rear area of the trunk on the floor is a ppi amp flush mounted- with a carpeted cover panel-
i have picts- but no server to put them up- but it would be easier explain-]
but you dont think it would deaden any sound- of muffel any- cool-
Posts: 8,142 |
It would have no audible effect.
Posts: 220 |
Posts: 491 |
Originally posted by dnewma04: It would have no audible effect. I was going to correct this statement until I saw the word "audible". I'll catch you slipping up some day.
1997 GL Sport MTX, Soon to be the fastest proven Zetec around.
Posts: 8,142 |
Originally posted by Sleeper: Originally posted by dnewma04: [b]It would have no audible effect. I was going to correct this statement until I saw the word "audible". I'll catch you slipping up some day.[/b]It would have a very very very small effect on the Qts of the enclosure. It may drop a .707 Qtc box down to a .69 or something like that.
Posts: 491 |
Yes but it would have been a difference.
Just giving you sh*t Mr. Expert.
