Any of you guys experience any problems with warping, discoloration, etc. from the heat that the Duratecs put out? I'm looking at picking up a CF hood, probably OEM style, and I was wondering what problems I would run into, and if I should place the factory lining from the OEM hood on the CF hood. I use my SSVT as a daily driver, so it's going to be exposed to all sorts of hell. Thanks, Matt
98 CSVT black/midnight
Trubendz catback, BAT inlet pipe, 75mm Pro-Flow, K&N open air on SCA cold air pipe, Optima Red Top in trunk, short shifter, Richbrook e-brake, lowered, side markers, mesh grille/bumper inserts
