JTruel Offline OP
Does anyone have the part number and brand/type (motorcraft double platinum or whatever) for the stock plugs?
yeah... the Autolite APP764 Double Platinum is the same exact plug..
Stick with that... period... don't go with the whole +4 crap..
NKG's are incredibly expensive and don't provide NEAR the improvement based on price... they are about the same
Ray
JTruel Offline OP
so the autolites are the way to go? Any difference between the platinum and double platinums? Are the stockers double platinum? Thanks for the help.
Z
Z
Yes, there is a difference between Plats and Double Plats. Be sure you get the Double Plats. It's worth the extra money.
- Zack WANTED: T-Red HEATED Side Mirrors FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps 2000 T-Red SVT 1995 LX V6 MTX (RIP)
JTruel Offline OP
thanks for the help guys. Now for the fun part- changing them- YIPPEEEE
for the rear bank.. don't remove ANYTHING.. you can change the rear bank with an extension, and merely raising the hood HIGHER than the prop rod supports it at. Lift the hood further than that and you get a straight shot at the rear cylinders.
Use anti-sieze on the new ones, and don't do it while the block is warm.. (warm+aluminum=soft...)
JTruel Offline OP
Ray, how do you hold the hood up higher than the prop rod?
More specifically, what do you use? broom handle? beer in hand clueless neighbor? I got both of these...
I actually opted for the "loves to be helpful wife" but at over 1 trillion dollars each (total is cumulative in maintenance, and upkeep for the life of the product) I would just go with the latter of your choices... at one beer per plug that is still only a 6-pack...
Though at one beer per plug the height may be lower and lower after each beer, so start with the back three..
Ray
JTruel Offline OP
Drunken neighbor it is!
FWIW, you can look the Motorcraft plug part number at www.motorcraft.com
The new fine-wire plugs, if used, eliminate the necessity of using double-platinums.
Steve
