liquidX Offline OP
A friend of mine that owns an Acura TSX is running H & R lowering springs, and just installed a set of KYB shocks yesterday. We all noticed that his car was higher than before the install, and knew it was not a "settling in" situation, because it was more of an inch in difference that the setup lifted his car.
After seeing this happen, I took it upon myself to call the suspension experts at Ground Control and ask them what this was all about. I spoke to one of the enginneers over there named Mark, and he told me that some shock manufacturers will fluctuate spring perch height between stock and up to an inch higher than stock!!!
Primarily KYB, but also other non-oem stut manufacturers are known to do this according to Mark. What he recommended me to do, is to measure my stock shock from spring perch to top-end of valve body, and to make sure that no matter which shock I buy, it meets the same measurement. I pass this information on to all you potential shock/strut buyers out there, so that you can avoid a serious dissapointment.
I am definitely measuring my Koni's when I get em...
XL
Intelligent ppl do a search to find you don't use KYB's with non-stock springs unless they are adjustable AGX's.
Well I had KYB GR-2 and Skunk2 Coilovers and evrything was fine.
Well, I'm a pretty smart guy, and I had not heard of the gross "normal" variation in perch height. I find it a bit unbelievable, but worth checking, I suppose.
I don't think you'd have this problem with Konis.
And, no, I don't recommed using the KYB with lowering springs, scattered anecdotal evidence of so-and-so's friend with such-and-such car notwithstanding.
But I have held the belief that KYB makes a quality strut for my minivan, or for someone with a Contour LX or GL who values ride quality over "sport."
Function before fashion. '96 Contour SE "Toss the Contour into a corner, and it's as easy to catch as a softball thrown by a preschooler." -Edmunds, 1998
So you think.
HAd them on the car for 4 years so can't be that bad! Maybe I just got lucky.
The KYB GR2 struts are stuts that are made for stock replacement, not for use with lowering springs.
~Alex
I'd be more willing to bet you don't know what a good handling car is suppose to feel like. (i.e. they've been blown for most of the time)
