I checked recently with Crutchfield and when using their car fitting program contours with the premium sound systems no full range speakers are listed
What gives? frown
have car manufactures stopped making 6X8 cutouts?
It's probably because they no longer make the car. I am pretty sure the focus could be used though, It has 5x7/6x8s in it too.
speaker choices come up when choosing the non premium option though
just browse the 5x7 or 6x 8 section rather than searching by your specific car, i found it gives you more results that way. once youve picked them just be sure to double check that it will fit in your car for depth, and youll be all set
Yeah, there are a lot of speakers out there, that most stores say wont fit.. but they dont have a clue, cause they just pop right in! trust me, Ive had some! just like stated above pick one of the same size hole, then make sure the depth clears, and you have found yourself a set!!
Oh, and I live only 30min from the Crutchfield outlet store here in VA, so I could find some Im sure! wink
'95 Tour LX
ZETEC MTX
TOO MANY MODS TO LIST ANYMORE!!
http://www.geocities.com/marine113
Best mod ever to my tour: A Beautiful passenger seat filler, that is my Beautiful Girl!!
Anyone know the maximum depth for the speakers/ pockets of out Contours?
I would suggest you try the Crutchfield Car Model Select again.
It came up blank for me the first time but now shows 3 models for the front and 6 models for the rear (although I thought both front and back doors used the exact same speaker size - not sure why the difference.)
Ron Offline
all infinitys will fit good.. All thoguh for my reference speakers i had to drill 1 new hole in each door to make them fit to my standards.. if ya gonna install em mine as well spend the extra time to make it perfect so u never have to do it again... and crutchfiels is overpriced they wanted 110 for a pair of rockfords i got em for 60 at at the wiz an electronic chain in long island
99 Silver frost Contour LX ztec..
35% tints all around..
Aiwa Deck w/ Infinity reference all around......
the reason for differences in speakers fitting front and back doors would be the mounting depth
Nope - Infinity Kappa 693.3i with silver cones wound't fit untill you trim some metal off
Regards,
Kirill
98.5 Contour SE Silver Frost (powered by Duratec 2.5L)
Nakamichi CD-45Z -> Phoenix Gold XS4300 -> Infinity Kappa 693.3i
\_ Blaupunkt ODx694
Moderated by  dnewma04_dup1
