Posts: 385 |
I have been searching through the junkyards around my area and have really only found 01+ Sable engines. I have searched through the archives a couple of times but have not found the answer I am looking for. Are the sable and the taurus engine the same. I found something about the water pump being different but is this going to be a problem with a 3L swap. I am looking at a 01 Sable with 29K on it, and wanted to make sure that it has the oval ports which I believe it does, and other than that its basically the same as the taurus, both differing from the escape with the center engine mount, wrong timing cover, and the older oil pan and components? Thanks guys, -Matt
Posts: 190 |
yes its the same and yes it will work
Brad
98' Red E0 Contour SVT - Project SVT Tour'
Pioneer Touch Screen Navigation / DVD, Infinity Speakers
Borla Stainless Cat-Back, AEM True CAI, High Flow Y-Pipe
3L Hybrid w/ 3L Valves, Window Automation, Torsen LSD
Posts: 718 |
so what came with oval port heads besides an escape and tribute?
1999 Cougar V6 MTX
SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
Posts: 9,602 |
Originally posted by 99cougar: so what came with oval port heads besides an escape and tribute?
All 01+ 3L Duratecs.
Even a few late year 2000's but they were such a FUBAR of parts bin clear outs you want to skip that year altogether.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 385 |
Thanks for the info guys. -Matt
Posts: 661 |
Where in WNY are you from?
Fast Cheap reliable
Pick two
Posts: 718 |
all this time i thought only the escape's came with the oval-port heads. so is there any difference at all in any of the '01 and up 3L duratecs or are they all the same?
1999 Cougar V6 MTX
Posts: 435 |
99Cougar:
Originally posted by DemonSVT: Originally posted by 99cougar: so what came with oval port heads besides an escape and tribute?
All 01+ long block assys will have the oval port heads.
Posts: 1,356 |
Originally posted by obicanobi0: Where in WNY are you from?
What Obi said... We just had a meet in Rochester... Check the Northeast section once in a while as we're planning on having a bunch more meets...
1999 Mystique LS V6
Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
Posts: 385 |
I am from Barker, about 20 minutes north of Lockport. I work in Tonawanda at a race car fabrication shop. However I also go to college in Flint, MI I am in NY from Jan-March, and then from July-Sep. The other months I at college. But we have done some pretty sweet engine setups like a twin turbo 67 Shelby and such, so I am hoping to be able to make a few tricks happen when I finally make the plunge into starting this project. -Matt
