I'm not sure if the Duratec uses hydraulic lash adjusters or if it uses something else, but my engine is making a brutal ticking noise. Its coming from the rear bank, which makes things even more difficult and fun.
So the question is... how difficult is it to replace a HLA? I'm not sure about the head design on this engine, but the camshafts probably have to be removed. If there isn't a constant tension on the timing chain, then I should be able to unbolt the drive gear from the cam and just slide it out of there... I saw my buddy do that with a Nissan engine once.
But with my luck, I'll probably have to remove the timing chain cover, which means the drive pulley will have to come off the crank, etc etc etc...
Has anyone had to do this? How big of a job was it?
Thanks guys.
