Posts: 1,152 |
Hey Guys, After installing My PS2 and Screen in stuff in my car, I get some bad engine whine. Its worse than before I installed it. I ripped everything apart in the trunk to find new grounds and couldnt come up with anything. I have a cap installed and left the ground disconnected and put everythingg back till I have time to mess with it. Did I discharge the cap?? Do I need to buy more resistors to charge it up again or can I just reconnect the ground? Also I noticed when I disconnected the RCAs from the back of the deck...the whining stops!!.
How do I fix this? Do i have to ground the deck better or what?? Man, I am glad this forum is here.
1998.5 T-RED SVT 18" Team Loco 142's W/ Dunlop Rubber 181.2hp@6900rpm/155tq@5000rpm LOTS OF MODS OF EVERY KIND.... ...Am I a guru yet??? No... not yet.
Posts: 1,083 |
wrap them in electrical tape. bet it stops!
Otherwise get better rca's and run them seperate from the power wires.
1998 SE ATX Dual exhaust Body conversion Nakamichi CD-40z HU Sound by Crystal Mobile Powered by a/d/s M860 AMP My Ride
Posts: 1,152 |
The RCA's are pretty good quality.... The Power wires are on a different side of the car...
Hmmmm
Posts: 1,083 |
i had the same problem with my isuzu and after i wrapped the rca and speaker wires with electrical tape it was all gone! If the power wire crosses the rca at any point wrap there as well.
like i said, it worked for me might not for you. worth a shot.
Posts: 1,152 |
Tony, Have any idea why I get the noise with the power inverter on?? Like a "buzz" through the speaker??
Ground?
Posts: 138 |
Joe, Do you have a ps2 or ps1. I bet that looks bad ass. Sorry about not replying to that PM, that was all gay.
Posts: 1,152 |
JD...PS2 man..pretty bad ass.
I got to figure all wired stuff out.
Posts: 138 |
PS is the ****, once its all in it'll be the pimp ****.... FO SHO
Posts: 138 |
PS2 is the ****, once its all in it'll be the pimp ****.... FO SHO
Posts: 1,083 |
Is the inverter hooked up through the cig lighter or do you have it hard wired? That's a bad source for noise. I think osny make an adapter for the ps2? Problem may also be your tryin to change power to much 12v-120ac-12.
Try grounding the chassis of the inverter to the vehicle chassis this may help. Or you could try using a ground loop isolater on the RCA cables.
Only sugestions. These may or may not work. You could also try a different converter. You can always return it. Wish i could help more. Maybe someone else will chime in.
