#1193683 02/21/05 08:24 PM
F
F
This may be a stupid question b/c i havent even checked my car yet, but its there a good spot to run rca's and power to the trunk or will i just have to force it through?
back seats the bottom pop right up, and the backs either fold down, or are torx bits, but u can get away without taking the backs of the backs seats with some fancy finger work.
2002 Cougar 2.5 duratec/ mtx-75 85,0000 Mondeo ST-200 wheels/BFG KDW NT black/black Spec Stage 1 Torsen T-2 Trubendz 2.5 flowmaster dual exaust apexi s-afc II K&N FIPK
If you are referring to running wires from the CABIN to the trunk, then you can run it along the floorboard, underneath the plastic door seal covers, and then between the rear seat and the rear quarter panel (BEHIND the seatbelts... ..)
Just remove the screw that hold each plastic piece to the floor, and then run it inside the small groove you will uncover.
Run power down one side, and RCA down the other.... not together
Ray
Unless the screws are stripped out like mine were. The pieces are flexible enough to tuck the wire under... I ran 4 gauge with out unscrewing them!
I would suggest runnning the power down the drivers side obviously, same side as battery. And run the RCA's and Remote together down the passenger side. You can fish those from the back of the HU behind the glove compartment with no troubles and it will come out very clean.
As far as getting the wires into the trunk. Run them however you want. I'm sure there are quite a few ways to do it. Just find some trim or panel piece to tuck it behind so it looks clean.
Moderated by  dnewma04_dup1
