i got a 93 taurus ( i know this is for contour, but someone might have had the same problem as its a ford with electric transmission)... fluid is correct level.. on expressway and take down ramp and stop behind other cars.... cars move so i try to pull up and NO GO....its like its in neutral... i then pull it out of drive and back to neutral and then to drive...nothing... so i put in in revers and then back to drive and it catches and drives on like there is no problem... next time i stop it does the same..... as long as you drive it works.. but after a stop it has to be put in reverse to get it to catch..... any suggestionsZ????
thanks in advance......
You might be better off posting this in the transaxle forum, but if the taurus engine isn't the CD4E, then don't expect much of a response besides the generic ones.
[color:"green"]-Matt R
'99 Tropic Green LX, Zetec, ATX
