Posts: 13 |
I will ask the dumbest question I ever ask... Where is the in car fuse box??? I've search and look in the owner book but even with it, I haven't found it... Thanks for helping a stupid guy with a stupid problem
Posts: 2,203 |
Heh, under the dash, near the steering wheel. Large white box, with a fuse diagram on the outside. Press the black button next to it, and the fuses will drop down. Helps to have a flashlight.
Posts: 13 |
Over the pedals??? Far awar under the dash? Strange place
Posts: 7,100 |
Yup.. right about where your knees are when you are driving... ask Demon.. lol.. Lean under the dash, and pull the little black trigger.. the box will swing down to reveal the fuses.. No stupid questions here... just repetitive ones...  Ray
'99 CSVT - Silver #222/276
Posts: 595 |
Il faut reculer le siege du conducteur jusqu'au bout. Tu vas te mettre tout plat au dos la, a la moquette au dessous du volant avec la tete vers les pedales. Si la portiere est ouverte, et la lampe en bas est allumee, tu pourrais voir la boite facilement. Sinon, prends la torche "et la lumiere fut."
Pardonnes-moi si mon francais craint. Forgive me if my french sucks.
Black 1998.5
3L Oval Port
Full HMS Transmission
Lots of other stuff
Ressurected 06/14/06
Posts: 13 |
Thanks for the answer, I'll look at that this afternoon! P.S.: muntus, you French is great, and Ray, I've use the search button, but I haven't found anything, maybe I'm really stupid
Posts: 7,100 |
Anyone smart enough to speak two languages well, isn't stupid.
As time goes by, and you browse the site more often, you will remember threads being started about certain problems, and what they used to describe that particular problem, so when you need to find the answer because YOU are having this problem, you will know which words to search for...
being new, you don't know what phrases people used, etc... no skin off anyone's back.
Ray
