Posts: 1,152 |
Hey Guys, Well I broke down and got a Screen for the Car today. Its a MA audio one. Has a real nice picture quality. Although, one tiny pixel is like blue. Is this defective. SHould I go exchange it? Or is this type of thing normal. Its not super bad, but its there.
You can really only see it on black stuff.
1998.5 T-RED SVT 18" Team Loco 142's W/ Dunlop Rubber 181.2hp@6900rpm/155tq@5000rpm LOTS OF MODS OF EVERY KIND.... ...Am I a guru yet??? No... not yet.
Posts: 8,142 |
Sounds like a burnt out pixel. Try to return it.
Posts: 1,152 |
Yeah I will see what I can do with that. Newman, I have some negine whine. I have searched and found a number of differant things. Now once in a while with my power inverter turned on (hard wired) I can hear that through my speakers. At idle I have a little bit of static then as I rpms go up I hear a whine. I have a Kenwood deck....4 chan amp and 2 chan amp (for subs) powered with 4 guage through a distribution block and cap (for the sub). I have the battery in the trunk so the power line/rca cables arnt that close. I am thinknig it is the ground of something. How do I stop this? I sanded off the areas so the paint is gone and yet I still have it. What should I do?
Thanks
Posts: 587 |
Whine is usually caused by ground loops... multiple grounds throughout the car. Try connecting all grounds locally to one access point, if that is a feasible option. Also.. if not an option, make sure that your ground cables are LESS THAN 3 feet long, each. You could always purchase a "ground loop isolator" from Rat Shack, if consolidating the grounds isn't an option.
I would go for the consolidation, first, as it is free, and almost sure to fix you up. (hopefully your grounds are "close" to each other..
HTH
Ray
Posts: 1,152 |
Well it is hard to get everything grounded in the same spot. Also the wire is longer than 3 feet and it needs to be to reach. I will go out and get one of ground loop things. Are they like a resistor? do they go "in-line"
Posts: 491 |
Originally posted by dnewma04: Sounds like a burnt out pixel. Try to return it. Burnt out pixels are black or white, although black is usualy a non-functioning pixel, any other color is a pixel that is stuck "on".
1997 GL Sport MTX, Soon to be the fastest proven Zetec around.
Posts: 1,152 |
Got it returned. Thanks guys.
