#1189177 02/17/05 01:34 AM
Arsenal Offline OP
87k Miles, when car is hot, Can hear the engine rattle at idle, seems to disappear after 1500 rpm.
I only bought the car 1 month ago, decided to check the plugs, they are the originals still! along with the wires! hoping to do them this weekend.
But any ideas on the rattle?
#1189178 02/17/05 01:36 AM
Valves clicking maybe? I don't know. What car/engine do you have?
98.5 T-red SVTour 05 Blue Yamaha R6 for sale PM me
#1189179 02/17/05 03:07 AM
timing chain? even tho i've only heard of this on startup tho
Mark 1998 T-Red SVT -Needs more Go 1999 Light Prairie Tan, Se Zetec www.cardomain.com/id/tour4reak
#1189180 02/17/05 04:21 AM
My contour 2.5 rattles every once in a while. Almost sounds as if its a loose heat shield. IS that possible?
Midnight Red 95 Contour SE 5 speed, fully loaded. kkm M.A.F. adapter w/ K&N ru-3530, single Magnaflow muffler w/ no res. 2.25" custom catback exhaust, grafite painted stock 95 SE rims on bfgoodrich touring T/A's, 35% window tint around.
#1189181 02/17/05 01:18 PM
Here's a trick I learned recently.
Take a long screwdriver and use it as a poor man's stethoscope. Put the sharp end to a part of the engine, and the handle to your ear. It suddenly becomes very easy to isolate noise sources this way.
Now, as for rattling or clicking, it could be a number of things, from normal to very bad, depending on where it's coming from.
Fuel injectors make a sort of ticking sound. That's normal.
The timing chain and valves should not clatter, but this is fixable (I think).
Rattles from the bottom end could be rod knock, whick is the last gasp. But, your description doesn't sound like that.
Function before fashion. '96 Contour SE "Toss the Contour into a corner, and it's as easy to catch as a softball thrown by a preschooler." -Edmunds, 1998
