Radiator replacement How-To..
Step 1. Contact Todras on CEG to order a CD for your car which includes this information..
(I will give you the ENTIRE write up THIS time.. first one is a freebie... the next one is $95 (the cd is only $8 SHIPPED) so it would be smart to buy it..)
CLICK THE PICTURES FOR FULL SCREEN VERSIONS!!!!Radiator
Removal
1. Disconnect the battery ground cable.
2. Drain the cooling system.
�µ 3. Disconnect the fan resistor electrical connector. (just below, and the to side of the radiator fan)
4. Lower the vehicle.
�µ 5. Disconnect the cooling fan electrical connectors. (two seperate connectors next to each other, each with plastic mating clips)
�µ 6. Disconnect the ground cable. (re-torque to 12Nm)
Vehicles fitted with A/C
�µ 7. Disconnect the A/C electrical connector.
�µ 8. Disconnect the A/C low pressure switch electrical connector.
All vehicles
�µ 9. Unclip the cooling fan and fan resistor cables.
Vehicles fitted with automatic transaxle
�µ 10. Disconnect the transaxle upper cooling line. (re-torque to 27Nm)
All vehicles
�µ 11. Disconnect the radiator lower hose.
Vehicle fitted with automatic transaxle
�µ 12. Disconnect the transaxle lower cooling line. (re-torque to 27Nm)
All vehicles
�µ 13. Disconnect the radiator upper hose.
14. Raise and support the vehicle. For additional information, refer to �«Section 100-02�».
�µ 15. Secure the A/C condensor.
�µ 16. Remove the A/C condensor bolts. Re-torque to 4Nm)
l Remove the two bolts.
All vehicles
�µ 17. Remove the radiator.
l Remove the four bolts. (re-torque to 10Nm)
l Remove the radiator.
Installation
�µ 1. To install, reverse the removal procedure.
Ray
