#1188967 02/16/05 10:13 PM
hi guys i was wondering i have my car a the shop to check my mounts because i have a lot of vibration in drive my mechanic says the mounts are good but he notice that the belt tensioner is not working properly so he says that's what causing the excessive vibration have any one had this promblem with the tensioner making the engine vibrate 97 contour gl 4cycl 97,865 all power
R.A
#1188968 02/18/05 02:39 PM
still waiting for a reeponse car went back to shop mounts were good and tight trying the tensioner
R.A
#1188969 02/18/05 02:40 PM
still waiting for a response car went back to shop mounts were good and tight trying the tensioner
R.A
#1188970 02/18/05 02:47 PM
9
Hi, something about that dosen't sound right. If it was a belt tensioner you would most likely see a power loss in steering ability, alternator output etc...due to a loose belt/ belt tensioner. I would think that if you had a bad/worn tensioner you would be able to feel it even at idle(or revving the engine at a standstill in neutral) since the tensioner could be slopping around on its mount. your vibration could be a worn CV axle, or a suspension part. Did they check those parts?? good luck, Jim
95SE tour MTX Silver/champagne custom dual side exhaust 16" ALT180's Wrapped in BFG COMP TA's 215/50 VR4 16.0 @ 91mph before wheels and exhaust mods.
#1188971 02/18/05 02:56 PM
does it vibrate in drive when you have the brake pedal in?
1999 Ford Contour SE Zetec with 137k miles. AIM Name: ContourAlf Yahoo IM: Contour_Freak
#1188972 02/18/05 03:45 PM
it vibrates sitting at a light but when you give it gas no vibration
R.A
#1188973 02/18/05 04:12 PM
Do that only when you have it in drive?
Does it also do that when you have it in park?
Might be a simple idle control valve issue giving you a low idle. I'd consider finding a different shop...
#1188974 02/18/05 04:56 PM
i have ben trying for a year to resolve this issue i thought it would be the mounts i replaced all 4 of them the bellt was jumping all over the place so he is going to take belt off and see what it will do then we have tryed everything what's your idea on this issue for a engine excessive vibration just sitting at a lite and the whole dash and sterring wheel vibrating????
R.A
#1188975 02/18/05 07:02 PM
H
H
Does it only do it in Drive? If so, EGR valve could be clogged.
#1188976 02/19/05 03:12 PM
update found out it was the rear tranny mount it was squashed all up put a new insert in and tremble free
R.A
